Antomore
1 year agoSignal Tap “Add Node” Window Too Tall and Unusable – Quartus Prime Pro 23.4
Dear Intel Support, I'm experiencing a severe graphical issue in Quartus Prime Pro 23.4 related to Signal Tap. When I open Signal Tap and click on “Add Node”, the window that appears has an extreme...
sstrell
1 year agoVery odd. What happens if you change the display resolution while the messed up Node Finder window is open?
Is the Node Finder messed up if you access it from the Assignment Editor instead of Signal Tap?
Worst case: uninstall and reinstall Quartus.
