13 years agoSignal probe pins flow?!
Dear Altera-Form community,
I would like to measure an internal FPGA (Stratix IV) signal with an oscilloscope. Therefore I tried to use Quartus' 11.1 Signal Probe tool. I clicked on "Tools->Signal Probe Pins..." in the menu bar and selected the signal I wanted to see. I assigned a valid, unused pin and then hit the "Start Check & Save Netlist changes" which starts a new signal probe compilation. Everything worked fine, no error appeared in the messages view. The changes were even shown in the change manager. Then I programmed the FPGA. However, i couldn't see the signal's value (and I know this signal exists) on the pin. On further investigation I discovered that the .sof-file's date was the time I did the last full compilation, which is totally different to the time I compiled the ECOs with the Signal Probe tool... So could you please tell me what I did wrong?! Thanks for any replays... :)
