12 years ago
Signal output cannot be synthesized, bad synchronous description.
Hi ,
I have been using vhdl programming for my project and I am trying to make a counter to count clock signal(clk_plstr),the counter is reset with another pulse signal(plsrep in my code).
I am successful in simulating the code but while I tried to implement in the design it gave me following error:
"Signal output cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release."
I am not sure what is this error about. Below is my part of code which I guess is giving this error:
process(clk_plstr,plsrep) ----clk_plstr=10mhz;plsrep=2.5khz
begin
pls<=conv_std_logic_vector(n,12);
if rising_edge(clk_plstr)then
count<= count+'1';
end if;
if(count<=pls)then
if(clk_plstr'event and clk_plstr = '1')then
output<='0';
else
output<='1';
end if;
else
output<='0';
end if;
if (plsrep='1')then
count<=B"000000000000";
end if;
end process;
fout<=output;
It would be very helpful if anyone can point out the problem by which I am getting this error.
I would really appreciate your help.
Thank you
    This is the whole code which I am working right now:
    begin
    if(plsrep='1')then
    count_reg<=B"000";
    end if;
    if(clk_plstr'event and clk_plstr='1') then
    count_reg<=count_next;
    if(count_reg<=pls )then
    output<='1';
    else
    output<='0';
    end if;
    end if;
    end process;
    count_next <=count_reg+'1' when(count_reg=B"000" and plsrep='1') else
    count_reg when (count_reg=B"000") else
    count_reg+'1' when (count_reg<pls)else
    --count_reg;
    B"000";
    fout<=output;
    end Behavioral_plstr;
    It might be I have done some silly mistake.
    Thank you.
    Well, you should have clk_plstr as an elsif to the plsrep. With the current code the plsrep is NOT a reset, as the clk gets priority over the reset. You should also assign output in the async reset part, or it will use the plsrep as a synchronous enable.
    And this still doesnt show the source of clk_plstr like I asked.
    Missing elsif makes the "bad synchronous description".
    Clock source is interesting related to timing analysis but doen't affect the synthesis of the shown code.
    I had made some small mistake and I figured it out.
    Thank you bertulus and tricky for explanation.
