12 years agoWell, you should have clk_plstr as an elsif to the plsrep. With the current code the plsrep is NOT a reset, as the clk gets priority over the reset. You should also assign output in the async reset part, or it will use the plsrep as a synchronous enable.
And this still doesnt show the source of clk_plstr like I asked.
