9 years ago
Signal not assigned in init state
I am working on a simple state machine but for some reason the output value is not assigned correctly.
First it is supposed to go into state init and assign default values to my 4x8bit internal signals (key_int), then should go to state assign to assign and combine the internal signals into 1x32bit output signal (key). And that is where it fails. When I run my test bench it always shows that key="00000000000000000000000000000000". Although key_int(0..3) are set to x"61" during the init phase. I already placed a counter in both states so I don't get a timing problem. I also replace the array with 4x std_logic_vector signals and assiged those during init with the same result. Surpringly: when I assign key directly in init it takes it.
What am I doing wrong here?
Btw I am using Quartus II 15.0.0. if that makes any difference.
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity buttonToKey is port(
    clk_50 : in std_logic;
    button : in std_logic_vector(5 downto 1);
    key: out std_logic_vector(31 downto 0)
end buttonToKey;
architecture behavior of buttonToKey is
    type state_type is ( init, evaluate, assign );
    signal state : state_type     := init;
    type my_array_type is array (0 to 3) of std_logic_vector(7 downto 0);
    signal key_int : my_array_type;
    signal index : integer := 0;
    signal count : unsigned( 18 downto 0 ) := ( others => '0' );
begin
    process( clk_50 )
    begin
        if rising_edge( clk_50 ) then
            if state = init AND count = 100 then                                                -- init and assign default char
                state <= assign;
                key_int( 3 ) <= x"61";                                         -- ASCII 'a'
                key_int( 2 ) <= x"61";
                key_int( 1 ) <= x"61";
                key_int( 0 ) <= x"61";
                count <= ( others => '0' );
            elsif state = evaluate then                                    -- check which button is pressed
                if button = "10000" then                                    -- button 5: increment ASCII character
                    state <= assign;
                    if unsigned( key_int( index ) ) = x"7A" then        -- run circular between ASCII char 'a' and 'z'
                        key_int( index ) <= x"61";
                    else
                        key_int( index ) <= key_int( index ) + 1;
                    end if;
                elsif button = "00001" then                                -- button 1: move to next position (start with 1)
                    state <= evaluate;
                    if index = 3 then
                        index <= 0;                                                -- overflow protection
                    else
                        index <= index + 1;
                    end if;
                else
                    state <= evaluate;
                end if;
            elsif state = assign AND count = 100 then                                        --  assign any changed keys to output
                state <= evaluate;
                key <= key_int( 3 ) & key_int( 2 ) & key_int( 1 ) & key_int( 0 );
            else
                count <= count + 1;
            end if;
        end if;
    end process;
end behavior;
Testbench: -- i took most of the test code out since the first transition from init to assign is not working
BEGIN
        -- code that executes only once
    button <= "00000";
    wait for 80 ns;
    button <= "00000";
    wait for 80 ns;
    button <= "00000";
    wait for 80 ns;
    button <= "00000";
    wait for 80 ns;
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
-- variable declarations
BEGIN
        -- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
-- clock generation process
process
begin
  clk_50 <= '1';
  wait for 10 ns;
  clk_50 <= '0';
  wait for 10 ns;
end process;
END buttonToKey_arch;
Cheers and thanks!
