9 years agoSignal not assigned in init state
Hello, I am working on a simple state machine but for some reason the output value is not assigned correctly. First it is supposed to go into state init and assign default values to my 4x8...
9 years agoIf you're doing an RTL simulation, all internals can be put on the waveform. Click on the sim tab, select the module you want to look at then click on the objects tab - all internal signals should be listed.
