12 years ago
seven segment display
hey everyone,
I am trying to write a code in Verilog which should display from 00 to FF on seven segment. i have two segment display on my fpga board.
It will be great if somebody can help me with code snippet. For convenience i am posting my code.
Do let me know where I am making the mistake. Hope to hear soon.
This is the code:
module hex2count(clk, HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7);
input clk;
output[6:0] HEX0;
output[6:0] HEX1;
output[6:0] HEX2;
output[6:0] HEX3;
output[6:0] HEX4;
output[6:0] HEX5;
output[6:0] HEX6;
output[6:0] HEX7;
//counter register
reg [39:0] counter ;
reg [3:0] shortCount ;
reg [6:0] HEX0, HEX1 ;
always @ (counter)
begin
case (counter[28:25])
4'h0: HEX0 = 7'b1000000;
4'h1: HEX0 = 7'b1111001;
4'h2: HEX0 = 7'b0100100;
4'h3: HEX0 = 7'b0110000;
4'h4: HEX0 = 7'b0011001;
4'h5: HEX0 = 7'b0010010;
4'h6: HEX0 = 7'b0000010;
4'h7: HEX0 = 7'b1111000;
4'h8: HEX0 = 7'b0000000;
4'h9: HEX0 = 7'b0010000;
4'ha: HEX0 = 7'b0001000;
4'hb: HEX0 = 7'b0000011;
4'hc: HEX0 = 7'b1000110;
4'hd: HEX0 = 7'b0100001;
4'he: HEX0 = 7'b0000110;
4'hf: HEX0 = 7'b0001110;
default HEX0 = 7'b1111111;
endcase
case (counter[32:29])
4'h0: HEX1 = 7'b1000000;
4'h1: HEX1 = 7'b1111001;
4'h2: HEX1 = 7'b0100100;
4'h3: HEX1 = 7'b0110000;
4'h4: HEX1 = 7'b0011001;
4'h5: HEX1 = 7'b0010010;
4'h6: HEX1 = 7'b0000010;
4'h7: HEX1 = 7'b1111000;
4'h8: HEX1 = 7'b0000000;
4'h9: HEX1 = 7'b0010000;
4'ha: HEX1 = 7'b0001000;
4'hb: HEX1 = 7'b0000011;
4'hc: HEX1 = 7'b1000110;
4'hd: HEX1 = 7'b0100001;
4'he: HEX1 = 7'b0000110;
4'hf: HEX1 = 7'b0001110;
default HEX1 = 7'b1111111;
endcase
end
endmodule
Muzammil
    Hi, what you get on your 7seg display ?
    I suppose the counter is counting :-).
    clk is clocking :-)
    Did you assign pins correctly ? Yes I suppose.
    I don't know Verilog : you have output[6:0] hex0; output[6:0] hex1; and later reg [6:0] hex0, hex1 ;
    --- Quote Start ---
    clk is clocking :-)
    --- Quote End ---
    Its just getting disappeared. I mean to say when code is downloaded seven segment flashes for a moment and goes off.
    This is the problem I am facing now.
    Don't know what to do now.
    Muzammil
    Did you simulate it? If no, do.
    Is this one file? Or do you have a higher level? Check your warnings for inferred wires. That warning means your bus wasn't defined as being N wide, and was reduced to 1 wide.
