12 years ago
Setting up Nallatech pci385 d5 board
Following the instructions on how to install the board I have run (after setting up the required environment variables):
$ aocl install
yielding:
aocl install: Running install from /opt/AOCL//board/pcie385n//linux64/bin
Using kernel source files from /usr/src/kernels/2.6.32-358.11.1.el6.x86_64
make: Entering directory `/usr/src/kernels/2.6.32-358.11.1.el6.x86_64'
Building modules, stage 2.
MODPOST 1 modules
WARNING: modpost: missing MODULE_LICENSE() in /opt/AOCL/board/pcie385n/host/linux64/driver/aclpci_drv.o
see include/linux/module.h for more information
make: Leaving directory `/usr/src/kernels/2.6.32-358.11.1.el6.x86_64'
Can't find the device!
Make sure:
1. Altera OpenCL Accelerator board is plugged into PCIe slot.
2a. The board either has a default OpenCL image in its flash, or
2b. If it's the first time using the board after power up, load
SOF using quartus_pgm and reboot the machine.
See documentation for the details.
Remeber that you can use 'reprogram' command to change SOFs once the
board is recognized as a PCIe device and this driver is loaded.
To see if the Altera Accelerator board is recognized as a PCIe device
run '/sbin/lspci | grep Altera'.
aocl install: failed.
Thus, I'm turning to suggestion 2b. This is the first time using the board after power up (first time ever in fact). However, what .SOF should I load to the FPGA? I presume this means using the Usb Blaster cable and the JTAG adapter.
What .sof should I use, and how should I call the quartus_pgm command?
quartus_pgm -c USB-Blaster -m JTAG whatSOF.sof ?
Thank you
