Setting environment variable for Questa FPGA Edition floating license server
UPDATE:
The issue is solved.
Although the daemon executables themselves were up to date, I had to install the Flexlm License Daemon v11.19.5.0 for Siemens ModelSim/Questa Intel FPGA software.
For other users in a similar situation, the steps were:
1. Change 'mgcld' to 'saltd', indicating the path which in my case is the same as for 'alterad' (home/user/Intel/quartus/linux64).
2. Install the License Server mentioned above (link in @AR_A_Intel 's message).
2.a. During installation, the license file to indicate is the recently changed .dat.
2.b. During installation, take note of the ports to which the license and daemon are linked. I was using port 1800 for the Quartus license, so I used other ports for this one.
3. In the client OS, set up the SALT_LICENSE_SERVER environment variable as [licenseport]@server.
Thank you for the support!
Regards.
