set operating condition agilex7
- 2 years ago
Why do you want to set the temp to 85C? If the timing passed in 100C, then it will also pass in 85C as 100C is the worst case as compared to 85C.
Unfortunately, there is no known way to set the temperature to other invalid value.
When running set_operating_conditions, you must only specify valid operating conditions for the current device. Run the get_available_operating_conditions command to return a list of all valid operating conditions for the current device.
Reference:
Richard Tan
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
