ldm_as
6 years ago"set_instance_assignment -name GLOBAL_SIGNAL OFF" -> what does it do?
Hello, What does the following attribute do: set_instance_assignment -name GLOBAL_SIGNAL OFF -to <signal_path> Is there a reason to apply this attribute to a reset line? Thank you!
Isaac_V_Intel
Contributor
6 years agoDimitry,
Hope that the solution works, if not respond this post to help you.
Isaac Vazquez.
