EGrom1
6 years agoset_global_assignment -name MESSAGE_DISABLE -entity ?
I would like to disable messages for specific locations. For example I have a global clock that could potentially cause problems in how it is used in many locations. At present I have one location wh...
sstrell
6 years agoThe easiest way to do this is use the GUI. Right-click the entity in the Project Navigator Hierarchy (or in any other part of Quartus where you have found this entity after performing at least Analysis & Elaboration) and choose to Locate (cross-probe) to the Assignment Editor. That way you can then choose the "Disable Message" assignment for the selected entity with the correct hierarchical path name to the entity already filled in for you.
#iwork4intel
