16 years ago
SDC ...NiosCpu_domain_synch.... unconstrained clock ?
This time i relay need some help to find the source of this warning message to get rid of it:
Warning: Node: SOPC_Nios2:inst|SOPC_Nios2_reset_clk_NiosCpu_domain_synch_module:SOPC_Nios2_reset_clk_NiosCpu_domain_synch|data_out was determined to be a clock but was found without an associated clock assignment.
The SDC report uncontrained paths -> clock status summary says :
Target : SOPC_Nios2:inst|SOPC_Nios2_reset_clk_NiosCpu_domain_synch_module:SOPC_Nios2_reset_clk_NiosCpu_domain_synch|data_out
Clock : *empty*
Type : Base
Status : Uncontrained
one of my sdc files has a
set_clock_groups -asynchronous -group { FPGA_CLK0
inst|the_pll_0|the_pll|altpll_component|pll|clk[0]
inst|the_pll_0|the_pll|altpll_component|pll|clk[1]
inst|the_pll_0|the_pll|altpll_component|pll|clk[2]
as well as another set_clock_group for each external clock input like those for the ethernet mac.
if have tried lots of set_false_path but nothing helped.
i think that need to cut a path between one clock (which one ?) and the target mentioned by the clock report.
i looked into the RTL viewer and the reported signals comes out of a DFF that is clocked by the external clock FPGA_CLK0 input that feeds the pll
if if set_false_path for ExternalClock FPGA_CLK0 and the reported signal, i get lots of uncontrained ports (as if nothing is contrained at all)
has anybody an idea or can point me to the right solution ?
    has nobody an idea ?
    i have this problem now with 7 different fpga projects
    it is always this domain_synch data out
    at least i found the source and could get rid of it
    always @ ( posedge CLK or negedge nRESET )
    the source was he negedge nRESET, removing this signal from the always block removed the unconstrained path.
