11 years ago
SCFIFO Seems Dead in simulation
Hi everyone,
I am trying to build a LPF, an averaging filter in particular, so I used the FIFO MegaFunction, however, when I simulated the design in ModelSim it turned out that the FIFO is not accepting data and not spitting out neither. The output is stuck on 0 value (Check the screenshot).
I tie up the 'read request' and 'write request' to one, so that it keep writing and reading on every clock edge.... is this correct?
And of course, I added the 'altera_mf' library to ModelSim using this command:
vsim -L altera_mf -lib work testbench -t 1ps
And no errors on compilation.
Any thoughts guys?
    --- Quote Start ---
    I told you you have connected aclr to clk
    --- Quote End ---
    Hhhhhh no I have not... the latter post is for a separate project. And this is how SCFIFO interface is organized! :) I am sure this is not the problem!
    --- Quote Start ---
    --- Quote End ---
    latter post has conflict of fifo if with first code you posted. Anyway can you see fifo signals in sim (I mean fifo own ports) such as clk, words etc.
    fifos don't go wrong so it is either user error or library issues.
    Can you please try a simple simulation with verilog and send it to me? If you have some time of course.
    --- Quote Start ---
    --- Quote End ---
    I did some work on fifo in verilog.
    If I changed your command to:
    vsim -t 1ps -L altera_mf_ver -lib work testbench
    then it worked (I used dc fifo with same clk connected to both clks but you can try your fifo)
    It is not project based so I can't send any files. Just instantiate dcfifo (I used quartus 14 64bit web edition) and wire it up.
    Okay Thank you very much... I was waiting for a good reason to install Quartus 14 although it is waiting in my hard disk :)
