S-parameter model of the power delivery network in Quartus functional simulation
Hello everyone,
Does anyone know if I can insert an s-parameter model of the FPGA power delivery network in Quartus or ModelSim functional/timing simulations? Has anyone done this already? Thank you, Cosmin12 Replies
FPGA reset is a bit more of a basic issue than increased IO jitter. Most likely the core supply falls below the POR trip point. I believe it's more likely caused by a not correctly operating voltage regulator than wrongly placed or insufficient bypass capacitors, but the difference should be obvious when looking at the "noise" waveform.
Thank you FvM. Yes, it seems to be related to the core supply because after choosing different capacitors the FPGA did not reset anymore. However, what I don't know is "how well" I fixed it and if it is only marginal and will reset again for a future re-compiled version of my design. This is why I am looking for a simulation tool that would take an s-parameter model and somehow provide me the information of "how well" I fixed the core supply.
