allenS1
2 years agoRunning Questa simulation with runtime arguments
Hello there, I'm trying to run a simulation in Questa using a testbench file that utilizes runtime arguments. The testbench file will check these runtime arguments and use the value to control the t...
allenS1
2 years agoHi Richard,
Thanks for the reply. I have tried to use $stop in my simulation, and it does pause the simulation without the "Are you sure you want to finish?" prompt, but the issue is that using $stop will not trigger the final procedure to run. Only using $finish will do that according to what I've read. In the screenshot you attached, you're not using a final procedure block, just putting more statements after the $stop command in the initial block.
I think that will be a good workaround for now, but it would just require an extra "run" command that needs to be typed in the transcript window after the simulation stops. I'll try to see if Siemens has a fix for this.
Thanks so much for your help.
Best,
Allen
