Running Questa simulation with runtime arguments
Hello Richard,
I've tried the example testbench from this link and I think I may have realized what the problem may be. It also did not work with the example but I believe it's because of what the $finish statement does in Questa.
For my own testbench and the example testbench, when it reaches the $finish statement, Questa will show a prompt asking "Are you sure you want to finish?". If you choose "Yes", the Questa application will close. Because of this, I always chose "No". Choosing "No" will allow the waveform to display and all the $display statements in the initial block will show in the Transcript window, but I think because I choose "No", the $finish command does not get registered, so the final block will not run.
So now my question is: why does Questa close when choosing "Yes" for this prompt, and how do I make it so that doesn't happen?
Best,
Allen
