10 years ago
RS232 rxd code
Hi :)
i'm new here and i need some help...
i work on project and i need to read from kind of machine some letters... there is an ascii code to all letter. this machine send words that i need to read them. in this words i need to check the letters (Y/N)?
for the start of this check i want to check one letter/char for example: ( or Y or / .
i know that machine send '1' (idle) always and when i press "reset" on this machine, the machine send words that i need to read with start bit+8 bits (data)+stop bit.
I'll be glad if someone would help me to write this code or give me examples of rxd codes :)
thanks...
    --- Quote Start ---
    I would use a timer for waiting, and add a state to check the timer.
    --- Quote End ---
    can you show me how?
    I could, but there is enough reference material on the www. Use your favorite search engine and search for VHDL Timer.
    You might think about changing the clock and use the wait timer to also time the bits.
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    its work :) rx was connected to rx and tx was connected to tx but its work just if rx to tx and tx to rx (wires)...
    thank you all :)
