Daniel99
1 year agoRestricted Fmax due to minimum period
I have created a simple project with a 500 MHz clock fed into a clock pin set for LVDS. This clock goes only to a divide-by-4 block (two flip-flops) and the resulting 125 MHz is fed to an output pin....
KennyT_altera
1 year agoI don't think you can refer to the table for restricted fmax.
Here is the definition:
Restricted Fmax considers hold timing in addition to setup timing, as
well as minimum pulse and minimum period restrictions. Similar to
unrestricted Fmax, the restricted Fmax is computed as if the rising
and falling edges of the clock are scaled along with Fmax, such that
the duty cycle (in terms of a percentage) is maintained. Refer to
hold timing reports (e.g., report_timing with the -hold option) or
minimum pulse width reports (report_min_pulse_width) for details about
specific paths, registers, or ports.
The report still doesn't show which nodes are causing the violation, but the help says to use
report_timing -hold
or
