Daniel99
1 year agoRestricted Fmax due to minimum period
I have created a simple project with a 500 MHz clock fed into a clock pin set for LVDS. This clock goes only to a divide-by-4 block (two flip-flops) and the resulting 125 MHz is fed to an output pin....
Daniel99
1 year agoAnd from table 19 I get the impression that LVDS and LVPECL can go above 500 Mbps (MHz?) if the differential voltage swing is sufficiently large(?)
