Daniel99
1 year agoRestricted Fmax due to minimum period
I have created a simple project with a 500 MHz clock fed into a clock pin set for LVDS. This clock goes only to a divide-by-4 block (two flip-flops) and the resulting 125 MHz is fed to an output pin....
KennyT_altera
1 year agoIf you look into the design above, you will need to solve the setup and hold timing by reducing the clock freq to match the restricted Fmax.
