Daniel99
1 year agoRestricted Fmax due to minimum period
I have created a simple project with a 500 MHz clock fed into a clock pin set for LVDS. This clock goes only to a divide-by-4 block (two flip-flops) and the resulting 125 MHz is fed to an output pin....
KennyT_altera
1 year agoDo you mind to attached your design for me to view? User cannot usually ignore the restricted Fmax.
- Daniel991 year ago
Of course. It is a very simple design just to test this. Hereby attached.
I can add that my main goal is to be able to feed a 500 MHz clock into the FPGA and directly divide it down to a lower frequency. I don't really intend to clock anything else than a divider at this high rate.
