15 years agoResource Usage in QuartusII Hierarchy window
quartus ii version before 10.0 can display resource usage of each module in the hierarchy window, just need to right click and select custom the column.
but i find these feature is lost in quartus 10.1, so i have to find that info in fitter report. Would altera pls add that feature in later version?4 Replies
Hi
is there any way to export it to file (report kind)? BR Meir - Altera_Forum
All the information is in the fit report.
- ldm_as
Anyway, what's the TLC command, which could be used in order to generate the Utilization Report by Hierarchy?
