Reset Release IP VHDL code not working
- 3 years ago
By the way, here is how your project netlist looks like in the RTL viewer. You should really check the connections and make sure if this is what you intended.
The connections are easily changed through portmapping as I had helped you earlier. You may check out the VHDL trainings as it covers this.
It seems like a very small project. What are you trying to do with this project? Are you just going to run simulations? Are you going to do hardware programming?
Nurina
I do not know what implementation is needed. I moved the RRIP into its own .vhd file and now my top-level file is riddled with errors. I simply cut and pasted all the RRIP code into a separate file and saved it into the same directory. I gave it its own architecture and begin statements. What else needs to be done? All the errors are coming up as part of something else not working (ghost errors I call them).
Thank you,
Drew
