3one5
4 months agoReset Release IP for Agilex needs Stratix 10 device files installed!
Just ran into the problem that Quartus Prime Pro 26.1 did not find the reset release IP which internally is named: altera_s10_user_rst_clkgate The reason in my case was that I had installed the A...
3one5
4 months agoHere is the archive of my design. It is intended for demonstration purposes for TimeQuest and has no real use by the way. This is the version that I got after installing Stratix 10 device files of course, but I guess that this does not matter.
It was not possible to attach the .qar (not accepted by the upload tool). So I zipped it in addition.
RichardT_altera
4 months agoI tried compiling the provided design and was able to compile it successfully. I’m not sure if there are any specific environment details or variables that could be causing this behavior.
For now, perhaps we can monitor the situation to see if other users encounter a similar issue, and revisit this if it affects a larger number of users.
Richard Tan
