Request to rehost a legacy floating license.
- AR_A_Intel
Hello
Welcome to INTEL forum. Alternatively, you can request a no-cost license for the Quartus Web/lite Edition by applying for the SW-QUARTUS-WE-FIX license in the Self-Service Licensing Center (SSLC).
Here’s the steps:
1. Login to https://licensing.intel.com/
2. Go to Sign up for Evaluation or Free licenses
3. Select Intel® Quartus® II Software SW-QUARTUS-WE-FIX
4. # of Seats is always 1 for Quartus Web Edition
5. Check the T&C box
6. Click Get License button
a. Check the option product “Intel FPGA Software SII-NONVOLENCRYP”
b. Add New Computer or Assign an Existing computer
7. Add the required fields
8. Click Generate License
You will be taken to the Licensing page, and you should be able to receive the email with license attached
- ErinM
Hi AR_A_Intel,
Thank you for the suggestion to request the free Quartus software license, but it doesn't appear to include the Nios II Soft Processor IP - F Core (features 6AF8_00A2 and 6AF7_00A2) that our designs require.
As viewed in Quartus 13.1.4 Web Edition's License Setup, with Host ID Values removed, here are the IP covered by our floating license that we wish to rehost:
Again, our concern is that access to the licensed IP relies on an old Altera USB dongle that sometimes fails to be recognized. If it will help, I can provide our current license .dat file via private message.
Thank you,
ErinM
- AR_A_Intel
The NIOS II license is available in the SSLC. Customer can generate the Nois II license there.
Guidance: https://fpgasupport.intel.com/AlteraLicensing/license/index.html --> Self Service Licensing Center --> Sign up for evaluation or No-cost licenses--> Discontinued - Nios® II/f Processor Intel® FPGA IP (License: IP-NIOS)
- AR_A_Intel
We do not receive any response from you to the previous reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- ErinM
Thank you. Generating fixed NIOS II licenses is the solution we were looking for.
