Reproducing the bitwise identical .rpd files in Quartus
Hello all,
I have a verified FPGA design with the programming files of .sof, .pof, .jic and .rpd. I have to reproduce the bitwise identical .rpd file by compiling the design in a different PC.
The original design files were generated by using Quartus Prime Version 18.1.1 Build 646 04/11/2019. Now, I compile the same design with the identical Quartus Version and Build number. Even though settings of fitter and analysis & synthesis are identical, newly generated .rpd file is different than the reference .rpd file.
I attached the screenshots of the settings that I use in the Quartus.
1- How can I sure that there is no difference in terms of functionality and timing?
2- Is there a way to generate bitwise identical .rpd file?
Thank you in advance.
Alpay
- KennyT_altera
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
