GOMEZ_IT
2 years agoreg~feeder REMOVE?
Good morning.
I'm trying to make 2-register synchronizers for the metstability problem on asynchronous signals.
Quartus automatically inserts the LUT between one register and another which calls regx...
GOMEZ_IT
2 years agoI don't need to achieve better results.
I just wanted to understand if there are any constraints or attributes to pass to the
synthesizer to connect the registers as desired.
Let's just say it's for educational purposes onlyFvM
2 years agoHi,
Quartus provides quite limited features to manually control fitting and routing results. Review this recent thread discussing a similar problem https://community.intel.com/t5/Intel-Quartus-Prime-Software/Altera-Register-Chain/m-p/1497097
Consider that Quartus is designed to fit complex circuits in an optimal way. You probably should take it as granted that it has no features to command a specific implementation of trivial circuits.
Even if you use wysiwyg_lcell low primitives to describe your circuit, it won't be necessarily exactly implemented as coded. The register cascade data path isn't even present in the lcell primitive.
