reg~feeder REMOVE?
between the output of the LUT (combout) and the input of the FLOP (datain) there is a switch.
Can this switch not be switched to exclude the LUT?as far as I understand, the datapath you are referring to has a specific dedication for SLOAD function. There's an optional register chain datapath, but I don't know if it's available in the present situation.
Basically fitter is selecting the best available datapath automatically, particularly considering timing constraints. Why do you worry about fitter results?
- GOMEZ_IT2 years ago
I don't need to achieve better results.
I just wanted to understand if there are any constraints or attributes to pass to the
synthesizer to connect the registers as desired. Let's just say it's for educational purposes only- FvM2 years ago
Quartus provides quite limited features to manually control fitting and routing results. Review this recent thread discussing a similar problem https://community.intel.com/t5/Intel-Quartus-Prime-Software/Altera-Register-Chain/m-p/1497097
Consider that Quartus is designed to fit complex circuits in an optimal way. You probably should take it as granted that it has no features to command a specific implementation of trivial circuits.Even if you use wysiwyg_lcell low primitives to describe your circuit, it won't be necessarily exactly implemented as coded. The register cascade data path isn't even present in the lcell primitive.
