Regarding the license for IP-10GMRPHY and IP-SLITE2
Dear Technical Support,
Good day!
Please provide the detail regarding the license for IP-10GMRPHY and IP-SLITE2
I want buy this IP 989-IP-SLITE2 but i don't see other information
Also for 989-IP-10GMRPHY
Is the license for the IP Core perpetual or time-limited?
While you are at it get the below info also:
Does the license support multiple users, or is it limited to a single user?
Is the license node-locked, or is it a floating license that can be used on multiple machines?
Is it only for arria 10 devices
In its datasheet it mentions other devices also
That is what my concern is that you are telling me arria 10 devices while data mentions other devices also
| 989-IP-10GMRPHY |
Mfr.'s Part #: | |
Manufacturer: | |
Description: | Development Software |
Lifecycle: | - |
Datasheet: | https://www.mouser.com/datasheet/2/612/xcvr_user_guide-1299761.pdf |
| 989-IP-SLITE2 |
Mfr.'s Part #: | |
Manufacturer: | |
Description: | Development Software SerialLite II MegaCore |
Lifecycle: | - |
Datasheet: | https://www.mouser.com/datasheet/2/612/ug_slite2-1099044.pdf |
Manuel
- AR_A_Intel
Hi
Welcome to Intel forum. Based on my understanding, The license for IP-SLITE2 is typically perpetual, allowing indefinite use after the purchase. The license module support both Fixed and Floating License.
Device Family Support:
While the IP-SLITE2 is compatible with Arria 10 devices, the datasheet mentions support for other devices as well. This means you can use it on those specified devices, but licensing terms may vary depending on the target device family.
- Mirosar1
Thanks AR_A_Intel, noted that.
Manuel - AR_A_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
