11 years ago
real in vhdl
hi all
i want to ask a question and i don't know if it possible in vhdl or how to make it.
if i have an eqution such as
x= m(a)+a*max(a)+b*sd_d(a)
and the values of a and b is as
a=1
b=1.5
a=1
b=1.75
a=1.5
b=0
and i want to substitue the values of a,b every time and check the x value with comparator
how i make it in vhdl.any idea please
    The values of a and b that you give can be represented using "fractional integer format". Assuming the values of a and b can be signed values, you can use a 4-bit integer in Q1.2 format. This format can represent the following values;
    Binary  Q1.2 Value
    01.11    1.75
    01.10    1.50
    01.01    1.25
    01.00    1.00
    00.11    0.75
    00.10    0.50
    00.01    0.25
    00.00    0.00
    11.11   -0.25
    11.10   -0.50
    11.01   -0.75
    11.00   -1.00
    10.11   -1.25
    10.10   -1.50
    10.01   -1.75
    10.00   -2.00
    You can use these numbers, along with the knowledge that a multiplication of two Q1.2 numbers yields a Q3.4 value (eg., -2.00 x -2.00 = +4.00 = 0100.0000b) and addition results in a Q3.2 number, to determine the bit-growth in your equation. The resulting value of x can either be used directly, or convergent rounded to whatever bit-width you need for your design.
    If none of this makes any sense, read these notes ...
    http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf
    Cheers,
    Dave
    you mean ichould convert this constant values first to binary and then to integer to multiply with integer signal
    --- Quote Start ---
    you mean i could convert this constant values first to binary and then to integer to multiply with integer signal
    --- Quote End ---
    Yes. There is no "rule" that says your constants must use floating-point. If fixed-point numbers represent the fractional part with the same precision as floating-point, then you will get the same answer. The math is the same.
    Cheers,
    Dave
