11 years ago
Reading and Writing Text File in VHDL
Hi guys.
I have tried run this coding. But, it has error. Why it happens? Btw, i refer to this website for the tutorial. http://vhdlguru.blogspot.com/2010/03/reading-and-writing-files-in-vhdl-easy.html . Thanks in advance
--include this library for file handling in VHDL.
library std;
use std.textio.all; --include package textio.vhd
--entity declaration
entity filehandle is
end filehandle;
--architecture definition
architecture Behavioral of filehandle is
--period of clock,bit for indicating end of file.
signal clock,endoffile : bit := '0';
--data read from the file.
signal dataread : real;
--data to be saved into the output file.
signal datatosave : real;
--line number of the file read or written.
signal linenumber : integer:=1;
begin
clock <= not (clock) after 1 ns; --clock with time period 2 ns
--read process
reading :
process
file infile : text is in "1.txt"; --declare input file
variable inline : line; --line number declaration
variable dataread1 : real;
begin
wait until clock = '1' and clock'event;
if (not endfile(infile)) then --checking the "END OF FILE" is not reached.
readline(infile, inline); --reading a line from the file.
--reading the data from the line and putting it in a real type variable.
read(inline, dataread1);
dataread <= dataread1; --put the value available in variable in a signal.
else
endoffile <='1'; --set signal to tell end of file read file is reached.
end if;
end process reading;
--write process
writing :
process
file outfile : text is out "2.txt"; --declare output file
variable outline : line; --line number declaration
begin
wait until clock = '0' and clock'event;
if(endoffile='0') then --if the file end is not reached.
--write(linenumber,value(real type),justified(side),field(width),digits(natural));
write(outline, dataread, right, 16, 12);
-- write line to external file.
writeline(outfile, outline);
linenumber <= linenumber + 1;
else
null;
end if;
end process writing;
end Behavioral;
