vlog-7 "Failed to open design unit file in read mode" error during simulation for Agilex7 board
Hello @BoonBengT_Altera
Thank you for the recommendations, I will work on that to hopefully provide a design which I can share to see if the error can be replicated.
Meanwhile, while trying to simulate a parallel project, I received a similar error:
# ** Error: (vlog-7) Failed to open design unit file "../../../components/channel_compensation/channel_compensation/channel_compensation_internal_10/sim/channel_compensation_i_iowr_bl_eststream0000hannel_compensation0.sv" in read mode.
# No such file or directory. (errno = ENOENT)
This time it is apparent that the unit involved has something to do with a Stream Interface (estStream) for my channel_compensation component, but again, this file does seem to exist in the specified folder.
Perhaps this indicates that the previous error was not an isolated problem.
In any case, I hope to be back soon with a design to share.
Thank you and regards,
Noah
