zjj
4 months agotiming impact
I performed compilation on two separate servers(A and B)using identical RTL source code and identical project configurations; however, the resulting timing violations differ between the two builds, w...
- 4 months ago
Can you take a look this https://community.altera.com/kb/knowledge-base/how-do-i-get-identical-results-from-compilations-in-the-quartus-prime-software/339140 to see you meet the criteria?
anonimcs
Contributor
4 months agoHi,
Were they clean builds (removed all the generated files and (q)db/ folder) ? Previously generated files can have an impact on how the compiler places things, which can impact timing pretty much
- zjj4 months ago
Yes, the compile env in the two serve machine is cleaning.
- KennyT_altera4 months ago
close the thread
