covfefe
23 days agoSystem Console master_read_memory fails above 7688 bytes on Agilex 5 (AXE5-Eagle)
A single master_read_memory of 7689 bytes or more never completes on an Agilex 5. It returns nothing, times out after 60 seconds, and leaves the JTAG channel closed so the next command fails too. 768...
covfefe
15 days agothank you for looking into it. were you able to replicate the issue?
covfefe
8 days agoHiZiYingE_Altera Just checking in to see if I should expect any update on this item?
- ZiYingE_Altera3 days ago
Contributor
Hi covfefe,
Sorry for the delayed response.
Would it be possible for you to provide the complete project in a .qar file and attach it as a .zip file?
We would like to investigate the issue using a similar device available in our lab.
This may require us to modify the target device and rebuild the design, so having the complete project would be very helpful for our analysis.
Thank you.
ZiYingE_Altera
