Synthesis - Incorrect SystemVerilog interface parameter override
- 3 years ago
Hi @fxmelvin ,
FYI. The bug had been fixed and implemented in Quartus Pro Edition version 22.4 internal build. Tested and worked fine check the image below:
Kindly wait for the version release. Thank you for your patience.
Sheng
Hi @fxmelvin ,
The feature requested will be planned in version 22.3. A patch will be added to that particular version. These are the feedbacks from internal engineering.
Sheng
@ShengN_Intel This is issue hasn't been fixed in Quartus Pro 22.3.
- ShengN_altera4 years ago
@fxmelvin Here is the latest update from internal team:
Moving this to 22.4 due to schedule. Will work with Verific to provide a fix for this.
