Strange issues on FPGA
I have another question. Originally, I had a Tx/Rx transmission module receiver, but I encountered a deadlock issue during testing, so I switched to parallel transmission. This time, I deeply realized that when receiving external signals, it’s important to process and wait for stability first.
I modified the module receiver using the same concept, and although it doesn't lead to illegal states causing deadlock, it sometimes fails to correctly receive data from Rx.
I am currently testing and inferring that the issue is also caused by the input changing simultaneously with the clock edge.
My Tx/Rx architecture:
My Tx transmission format is:
Start bit + 12bit data(LSB to MSB) + Stop bit = total 14bit, refer to:
My Receiver Code:
module receiver.v
Result
On the left is the SPI data, which is sent through Tx after reversing the MSB, and on the right is the data received by Rx:
I have confirmed that the timing and state are both normal:
First data:
| Start bit | Tx Data | Stop bit | Rx Data |
| 0 | 0110 0000 0010 | 1 | 0x406 |
Sixth data:
| 0 | 1110 0000 0010 | 1 | 0x007 |
Observing the execution time of the shift_reg based on the changes in GPIO.
if(current_state == RECEIVE) begin shift_reg <= {RX_sync, shift_reg[11:1]}; bit_count <= bit_count + 1; gpio <= ~gpio; end
Due to the use of a synchronization register, the GPIO will be delayed by one clock cycle.
//* ----- Synchronization Register ----- *// reg [1:0] rx_sync; // Registers are updated on every rising clock edge always @(posedge clk) begin // Synchronize the external signal step by step to the FPGA internal clock rx_sync <= {rx_sync[0], rx}; end // Sync Signal wire RX_sync = rx_sync[1];
I initially had no way to solve this issue, but referring to a recent discussion[1], if I use oversampling during Rx reception, it should help avoid the problem of the input Rx changing simultaneously with the clock edge.
So generally, when designing a receiver, oversampling is used to solve this issue?
