Quartus edition requirement for MAX10 DD device
- 1 year ago
Thank you FvM for the answer.
Hi @Trowa ,
Which Quartus Lite version are you using?As mentioned by FvM, the MAX10 DD device is supported starting from Quartus version 22.1 onwards. I recommend to install the latest Quartus Lite version.
Richard Tan
as stated above, you need Quartus 22.1 or newer for MAX10 DD. According to release notes, CentOS 8.2 is required for Quartus 22.1 Linux version. Later Quartus versions seem no to support CentOS at all.
I notice that CentOS 7.9 support ended mid 2024, you may want to rearrange your tool chain anyway. I'd think about moving to recent Ubuntu version.
I'd start however with a quick try if Quartus 22.1 is running under Centos 7.9 although not officially supported.
Regarding MAX10 and Cyclone series support, there's no difference between Quartus Std and Lite version.
Best regards
Frank
Hi Frank and Richard,
Thanks you all.
I had downloaded 22.1 and 24.1 lite edition, and both are installed fine.
DD device is recognized fine as well.
