ALMSlinger
2 years agoThey use common reset that is synchronous to the clock generated by the pll. The same clock that is input to the clock bridge. I even tried to add a parallel reset bridge which did the same thing as the clocks. But that doesn't help. I get the same error.
Thank you.
Best regards.
- sstrell2 years ago
Can you show screenshots of parameters and how you're connecting things?
