NTA's avatar
NTA
1 year ago
How to configure Dual Compressed Images on MAX10 without IP core?
Hello, we have a PCB with a MAX10 FPGA (M50SAE144I7G) and would like to make use of the dual configuration feature. The PCB features a switch that pulls the FPGA's dedicated config_select pin to HI...
  • WZ2's avatar
    1 year ago
    Hi there,
    What you are encountering now seems to be a config issue. It looks like the previous problem with sof -> pof conversion has been resolved. Unfortunately, the root cause of the failure is still unclear. So I would like to further confirm the following:
    1. Loading the standalone sof file included in the pof works fine, right?
    2. In step 6, the CPF mode is set to Internal Configuration.
    3. Does the Programmer show any specific error messages?
    4. If you reduce the JTAG speed to 6 MHz in the Programmer, does it help to resolve the issue?
    WZ
