MEIYAN_L_Intel
6 years agoHi,
I am sorry for misunderstanding to the problem occurred.
The problem might be due to the environment variable for Quartus is not set correctly.
You can refer to Chapter 2.5 (Windows) or Chapter 3.5 (Linux) to set and point to the Quartus Pro version with command"QUARTUS_ROOTDIR_OVERRIDE" as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf
CJuni1
6 years agoHi,
I have set this variable, but the aoc compiler always open the standard version. If I try to open manually, it opens the pro version. I have tried to change the script to open the pro version, but it didn't work either. Is there any way to change that?
