DisplayPort Sink (Quartus 18.1) – horizontal pixel offset.
Hi vilem,
My apologies for the delayed reply, and thanks for the update — the CRC reset restoring alignment is a very useful finding.
Regarding a newer CRC on Quartus 18.1, the Clock Recovery Core is delivered with the design example for that Quartus release and is not supported as a standalone upgrade from a newer Quartus into 18.1. As a runtime workaround, automating the CRC reset you already validated (when the alignment is wrong).
I have the following questions to clarify:
- What is the device family/OPN, link rate and lane count set?
- When the image is shifted, do MSA values (HSTART, HTOTAL, HWIDTH) stay the same, or do they change? Also, do msa_lock / rx_vid_locked / BER counters glitch at that moment?
- While the image is shifted, does the DP Sink still declare video lock (rx_vid_locked asserted)?
On the extender: try a lower negotiated link rate or fewer lanes, check the firmware, since the failure only appears with the extender.
Ven
- vilem28 days ago
Hi Ven,
ad 1) DP1.2-VisionXG-Fibers(S), 4 optical pairs, HBR2
ad 2) When the image is shifted all MSA values stay the same.
ad 3) When the image is shifted DP Sink still declare video lock.
In the meantime, we found that CRC itself amplifies the consequences of the issue cause. When we removed CRC from the design the frames did not stay shifted. There is only 1 frame shifted and the following frames are correct. The damaged frame is indicated in changing of SOL/SOF, EOL/EOF signals on the DP Sink output.
Vilem
