GOMEZ_IT's avatar
GOMEZ_IT
6 months ago
CYCLONE IVE ODDR delay mismatch
Hello Altera Experts! I am using Quartus Standard 24.1.. I'm building a 10-bit parallel output interface to drive a DAC. I'm using the oddr (ALTDDIO_OUT) registers so that all bits output simultane...
  • ShengN_altera's avatar
    ShengN_altera
    5 months ago
    The routing delay difference due to different type of pin assigned.
    The bit fpga_dac_CHA[3] using this type of pin:
    While other bits using these type of pin:
    Different pin type will have different internal routing delay and this is fix one which cannot be changed.
    So if change bit fpga_dac_CHA[3] and fpga_dac_CHB[3] pins to for example PIN_115 and PIN_120. The timing will be similar for all bits:
