YuanLi_S_Intel
3 years agoIt is possible to share me the screenshot of your programmer? meanwhile can you try to reduce the TCK frequency of USB Blaster II to 6MHz?
- AWann13 years ago
I am using a USB Blaster, Rev C, I think it's only TCK frequency is 6MHz
Attached is the Programmer screenshot.
I did an experiment:
I found that we had some old EPCS64SI16N memory in our inventory. I removed the EPCQ memory, and put the EPCS in its place. I remade the programming file to work for that memory. But I still get the same error: Flash Loader IP not loaded on device 1
