AWann1
3 years agoCyclone III - Flash Loader IP not loaded
Hello all.
I am trying to program a Cyclone III LS with a new .jic file.
I made modifications to the code and compiled it in Quartus 13.
However, these boards were built relatively recently an...
YuanLi_S_Intel
3 years agoCan you check if the device part number is selected correctly in the quartus design? Also, the device part number and flash part number EPCQ64A is correct during JIC generation.
- AWann13 years ago
Yes, I confirmed the FPGA Device is correctly selected, EPC3LS70, and the memory is set to EPCQ64A.
I also checked the box in the convert programming file window that says "Disable EPCS ID check"
