Hi @Ranesh ,
In your updated code, there are differences between the lines 144 and 151.
Line 144:
s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8];
Line 151:
s_output_data[d] <= s_in_data[((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) -: 8];
For line 151, if change s_outbytecount to c_IN_DESC_BYTE_CNT also produce the error below:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(151): index 136 is out of range [15:0] for 's_in_data'
For line 144, if change c_IN_DESC_BYTE_CNT to s_in_empty and with previous if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty))), there'll be no error produced as well.
So you're comparing two different things. Let me know if you have any further concern.
Sheng
Hi Sheng,
Please don't compare line 144 and 151, they are not causing this error. If you change line 144 to have
(c - c_IN_DESC_BYTE_CNT) > 2, it will produce negative index for s_in_data and similarly, in line 151, if
(d - s_outbytecount) > 2, it will produce negative index for s_in_data. This is because W_MODULE_DATA = 16.
Please don't change any of these lines.
Please compare lines 142 (commented), 143 with line 150.
If line 142 is used, the compiler produced following error:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(144): index -8 is out of range [15:0] for 's_in_data'
If line 143 used, which does not use s_in_empty in for loop if statement, the compiler does not produced any error
For this error, you have mentioned:
You can't use logic type s_in_empty in for loop if statement.
Please note that line 150 is using a logic type s_outbytecount in for loop if statement, which does not cause any synthesis error. This shows that a logic type can be used in for loop if statement.
Thank you.
Ranesh
