RZhen11
6 years agoRapid Compilation never works for my Arria10 project with only change to .stp
20.2 pro, Arria10
Even if I only disable Trigger Enable for single signal, a whole compile is needed.
Always getting the same error when attempting Rapid Recompile.
Error(20279): Rapid Recomp...
sstrell
6 years agoAs mentioned in the error, have you enabled the creation of the intermediate Fitter snapshots?
Since you're turning something off instead of adding something (like tapping an additional node), it should work. When you make the change, does the status bar at the top of the .stp file say that you can/should perform a RR to implement the change?
#iwork4intel
RZhen11
6 years agoThanks for your attention.
I indeed didn't know "Enable intermediate Fitter Snapshots" needs to be turned on, until FAE pointed out for me.
Now it seems working although it's not real RAPID, only slightly faster for me.
