11 years agoRAM 1-port mega function - Single Port Ram module
hello,
I created a memory ram 1k x 8bit through the MegaWizard by Quartus II. The process generated the following code that works very well:
-- megafunction wizard: %RAM: 1-PORT%
-- GENERATION: STANDARD
-- VERSION: WM1.0
-- MODULE: altsyncram
-- File Name: RAM.vhd
-- Megafunction Name(s): altsyncram
-- Simulation Library Files(s): altera_mf
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY RAM IS
PORT(
address : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
wren : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
END RAM;
ARCHITECTURE SYN OF ram IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (7 DOWNTO 0);
COMPONENT altsyncram
GENERIC(
clock_enable_input_a : STRING;
clock_enable_output_a : STRING;
intended_device_family : STRING;
lpm_hint : STRING;
lpm_type : STRING;
numwords_a : NATURAL;
operation_mode : STRING;
outdata_aclr_a : STRING;
outdata_reg_a : STRING;
power_up_uninitialized : STRING;
read_during_write_mode_port_a : STRING;
widthad_a : NATURAL;
width_a : NATURAL;
width_byteena_a : NATURAL
PORT(
address_a : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
clock0 : IN STD_LOGIC ;
data_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
wren_a : IN STD_LOGIC ;
q_a : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
END COMPONENT;
BEGIN
q <= sub_wire0(7 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP(
clock_enable_input_a => "BYPASS",
clock_enable_output_a => "BYPASS",
intended_device_family => "Cyclone IV GX",
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram",
numwords_a => 1024,
operation_mode => "SINGLE_PORT",
outdata_aclr_a => "NONE",
outdata_reg_a => "CLOCK0",
power_up_uninitialized => "FALSE",
read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ",
widthad_a => 10,
width_a => 8,
width_byteena_a => 1
PORT MAP(
address_a => address,
clock0 => clock,
data_a => data,
wren_a => wren,
q_a => sub_wire0
END SYN;
-- CNX file retrieval info
-- Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0"
-- Retrieval info: PRIVATE: AclrAddr NUMERIC "0"
-- Retrieval info: PRIVATE: AclrByte NUMERIC "0"
-- Retrieval info: PRIVATE: AclrData NUMERIC "0"
-- Retrieval info: PRIVATE: AclrOutput NUMERIC "0"
-- Retrieval info: PRIVATE: BYTE_ENABLE NUMERIC "0"
-- Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8"
-- Retrieval info: PRIVATE: BlankMemory NUMERIC "1"
-- Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0"
-- Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0"
-- Retrieval info: PRIVATE: Clken NUMERIC "0"
-- Retrieval info: PRIVATE: DataBusSeparated NUMERIC "1"
-- Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0"
-- Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_A"
-- Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0"
-- Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone IV GX"
-- Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0"
-- Retrieval info: PRIVATE: JTAG_ID STRING "NONE"
-- Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "0"
-- Retrieval info: PRIVATE: MIFfilename STRING ""
-- Retrieval info: PRIVATE: NUMWORDS_A NUMERIC "1024"
-- Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0"
-- Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_A NUMERIC "3"
-- Retrieval info: PRIVATE: RegAddr NUMERIC "1"
-- Retrieval info: PRIVATE: RegData NUMERIC "1"
-- Retrieval info: PRIVATE: RegOutput NUMERIC "1"
-- Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
-- Retrieval info: PRIVATE: SingleClock NUMERIC "1"
-- Retrieval info: PRIVATE: UseDQRAM NUMERIC "1"
-- Retrieval info: PRIVATE: WRCONTROL_ACLR_A NUMERIC "0"
-- Retrieval info: PRIVATE: WidthAddr NUMERIC "10"
-- Retrieval info: PRIVATE: WidthData NUMERIC "8"
-- Retrieval info: PRIVATE: rden NUMERIC "0"
-- Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
-- Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_A STRING "BYPASS"
-- Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_A STRING "BYPASS"
-- Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone IV GX"
-- Retrieval info: CONSTANT: LPM_HINT STRING "ENABLE_RUNTIME_MOD=NO"
-- Retrieval info: CONSTANT: LPM_TYPE STRING "altsyncram"
-- Retrieval info: CONSTANT: NUMWORDS_A NUMERIC "1024"
-- Retrieval info: CONSTANT: OPERATION_MODE STRING "SINGLE_PORT"
-- Retrieval info: CONSTANT: OUTDATA_ACLR_A STRING "NONE"
-- Retrieval info: CONSTANT: OUTDATA_REG_A STRING "CLOCK0"
-- Retrieval info: CONSTANT: POWER_UP_UNINITIALIZED STRING "FALSE"
-- Retrieval info: CONSTANT: READ_DURING_WRITE_MODE_PORT_A STRING "NEW_DATA_NO_NBE_READ"
-- Retrieval info: CONSTANT: WIDTHAD_A NUMERIC "10"
-- Retrieval info: CONSTANT: WIDTH_A NUMERIC "8"
-- Retrieval info: CONSTANT: WIDTH_BYTEENA_A NUMERIC "1"
-- Retrieval info: USED_PORT: address 0 0 10 0 INPUT NODEFVAL "address"
-- Retrieval info: USED_PORT: clock 0 0 0 0 INPUT VCC "clock"
-- Retrieval info: USED_PORT: data 0 0 8 0 INPUT NODEFVAL "data"
-- Retrieval info: USED_PORT: q 0 0 8 0 OUTPUT NODEFVAL "q"
-- Retrieval info: USED_PORT: wren 0 0 0 0 INPUT NODEFVAL "wren"
-- Retrieval info: CONNECT: @address_a 0 0 10 0 address 0 0 10 0
-- Retrieval info: CONNECT: @clock0 0 0 0 0 clock 0 0 0 0
-- Retrieval info: CONNECT: @data_a 0 0 8 0 data 0 0 8 0
-- Retrieval info: CONNECT: @wren_a 0 0 0 0 wren 0 0 0 0
-- Retrieval info: CONNECT: q 0 0 8 0 @q_a 0 0 8 0
-- Retrieval info: GEN_FILE: TYPE_NORMAL RAM.vhd TRUE
-- Retrieval info: GEN_FILE: TYPE_NORMAL RAM.inc FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL RAM.cmp FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL RAM.bsf FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL RAM_inst.vhd FALSE
-- Retrieval info: LIB_FILE: altera_mf
However, some features do not meet my needs. First problem: The Altera design, has two data bus, one to input (write) data and another to output data (read). Second problem: The Altera desing, has only one control input (write data enable). Third problem: All buses, are STD_LOGIC_VECTOR. I need a device, that has a bi-directional data bus, type std_logic (not vector). I need a device, that has a address bus, type std_logic (not vector). I need a device, that has one read/write pin control (RW) and one chip select to to put the bi-directional data bus in tri-state (CS). Something like the following port:
ENTITY RAM IS
PORT(
A0 : IN STD_LOGIC;
A1 : IN STD_LOGIC;
A2 : IN STD_LOGIC;
A3 : IN STD_LOGIC;
A4 : IN STD_LOGIC;
A5 : IN STD_LOGIC;
A6 : IN STD_LOGIC;
A7 : IN STD_LOGIC;
A8 : IN STD_LOGIC;
A9 : IN STD_LOGIC;
D7 : INOUT STD_LOGIC;
D6 : INOUT STD_LOGIC;
D5 : INOUT STD_LOGIC;
D4 : INOUT STD_LOGIC;
D3 : INOUT STD_LOGIC;
D2 : INOUT STD_LOGIC;
D1 : INOUT STD_LOGIC;
D0 : INOUT STD_LOGIC;
CLK : IN STD_LOGIC := '1';
CS : IN STD_LOGIC;
RW : IN STD_LOGIC
END RAM;
I got get close this result... I got change buses and created de CS pin control... But, I have serius problems with the bi-directional data bus... I could not create a correct logic to manage the bi-direcinal bus in the three possibilities: READING, WRITING and DISABLED. I'm still learning VHDL and I need some help from you guys!!! Thank you very much. :)
