16 years ago
Qurtus vs Modelsim
I wrote code in ModelSim and this code generate wave, who I expected, but Quartus genrate error
Error (10822): HDL error at klaw.vhd(110): couldn't implement registers for assignments on this clock edge
What should I think about this?
    I have problem. In wector file I have node Next_State, but in report whis value don't appear.
    Compiler shown such a this mesagge
    --- Quote Start ---
    Warning: Compiler packed, optimized or synthesized away node "Next_State". Ignored vector source file node.
    --- Quote End ---
    What this mean?
    process(clk, rst)
        begin
            if( rst = '0') then
                Present_State <= Read_but;
            elsif( rising_edge(clk) ) then
                Present_State <= Next_State;
            end if;
        end process;
        process(Present_State, key1, key2, key3, done)
        begin
            case Present_State is
            when Read_but =>
                start_ps2 <= '0';
                if(key1 = '1') then
        --            code_temp <= PushF5;
                    code_choice <= "00";
                    Next_State <= Push;
                elsif(key2 = '1') then
        --            code_temp <= PushLeft;
                    code_choice <= "01";
                    Next_State <= Push;
                elsif(key3 = '1') then
        --            code_temp <= PushRight;
                    code_choice <= "11";
                    Next_State <= Push;
                else
        --            code_temp <= (others => '0');
                    code_choice <= "ZZ";
                    Next_State <= Read_but;
                end if;
            when Push =>
                start_ps2 <= '1';
                if (done = '1') then
                    start_ps2 <= '0';
                    Next_State <= Break;
                    code_choice <= "10";
                else
                    Next_State <= Push;
                end if;
            when Break =>
                start_ps2 <= '1';
                    start_ps2 <= '0';
                    Next_State <= Release;
                else
                end if;
            when Release =>
                start_ps2 <= '1';
                    start_ps2 <= '0';
                else
                end if;
            end case;
        end process;
        code <= PushF5 when code_choice = "00" else
                PushLeft when code_choice = "01" else
                PushRight when code_choice = "11" else
                ReleaseKey when code_choice = "10" else (others => 'Z');
    And what mean this message?
    --- Quote Start ---
    Warning: Converted tri-state buffer "code[0]" feeding internal logic into a wire
    --- Quote End ---
    Next_State isn't a real signal in your design. It doesn't represent an FPGA resource. Present_State is the only real FSM signal, represented by a number of registers. They are loaded with a the new state vector on every clock edge depending on actual state and input conditions. Ony real signals can be shown in Quartus simulation are accessed by SignalTap II.
    Also internal tri-state signals don't really exist in an FPGA. They can be used to describe internal connections, but are converted by the design compiler to multiplexers and other logic elements. The warning informs you about this fact.
