12 years ago
Questions about arrays declaring and initializing in VHDL
Hello. Now i should write on VHDL. And any things which was simple on Verilog is difficult on VHDL and i can't understand it.
I read many manuals but i don't know about right technics about work with arrays in VHDL.
I use Quartus II 13.0.
Underwritten simple example don't compile without errors and i 2 week can't solve this problem. If i can compile this project now, i will can compile all other projects in future.
Input is 2 bit number - "input_impulses". It checked on input clock - "clk", and this inputs changed array index - "array_index". And array index select element of array to output from this module. But i don't know what i was changed in code for good compilation. I rewrite many things but it is not work.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity code_on_vhdl is
    port (
        clk : in std_logic;
        input_impulses : in std_logic_vector (1 downto 0);
      output_impulses : out std_logic_vector (9 downto 0)
end code_on_vhdl;
architecture Behavioral of code_on_vhdl is
signal array_index: std_logic_vector (1 to 0);
type array_type is array (3 to 0) of std_logic_vector (9 downto 0);
signal MY_ARRAY : array_type;
begin
MY_ARRAY <= (("0000000000"), ("1010101010"), ("1111001111"), ("1111111111"));
    process(clk)
    begin
        if rising_edge(clk) then
            if (input_impulses = "00") then
            array_index <= "00";
            else
                    if (input_impulses = "01") then
                    array_index <= "01";
                    else
                        if(input_impulses = "10") then
                        array_index <= "10";
                        else
                            if(input_impulses = "11") then
                            array_index <= "11";
                            end if;
                        end if;
                    end if;
            end if;
        end if;
    end process;
    output_impulses <= MY_ARRAY(to_integer (unsigned (array_index)));
end Behavioral;
I read about next rules and i change my code like this:
1) Array index is only integer value. They should be converted - "MY_ARRAY (to_integer (unsigned (array_index)))". For converting i connect "use ieee.numeric_std.all;".
2) I use aggregates for initialize array values - MY_ARRAY <= (("0000000000"), ("1010101010"), ("1111001111"), ("1111111111")); But i don't know how it writing, but this haven't errors in compilation.
3) And i need only this array - 4 piece of 10 bit std_logic_vector.
I can't use 4 piece of integer type. Because it have constrained by 32 bits, but my numbers in real projects have numbers more than 37 bit.
Thanks in advance for any help.
    here is your problem:
    it is a null array, as 1 is higher than 0. I think you meant (1 downto 0)
    Another point - why is array index a std_logic_vector? save your fingers from RSI, and make it:
    signal array_index : integer range 0 to 3;
    --- Quote Start ---
    --- Quote End ---
    tricky, thanks for your help - you are absolutely right.
    1) I changed:
    To:
    signal array_index: std_logic_vector (1 downto 0);
    2) Similar mistake - I changed:
    To:
    type array_type is array (3 downto 0) of std_logic_vector (9 downto 0);
    And my program was compiled in Quartus II.
    --- Quote Start ---
    --- Quote End ---
    Thank you for your advice - i will be use integer type for array index in future projects.
    Problem was solved :-P
